caterpillar elektro ET16KT
Hello everyone!
Does somebody know what is eror 51 at model ET16KT
year 2002
Thanks, Marko
  • Posted 14 Jan 2008 22:46
  • Discussion started by marko
  • Croatia
Hi,
fault was in the H Bridge card, I bought new one ,finally forklift works properly.
Thank you all for the suggestions , it was helpful!
Dragan
  • Posted 20 Nov 2014 07:54
  • Reply by marija_p
  • bosna i hercegovina, Bosnia and Herzegovina
mprolic@hotmail.com
washed it?
no brainer
dry it out (with a heat gun or hair dryer if you have one)
blow out all switches and motors with compressed air
anything you can try so to make moisture evaporate
then...
connect battery and deal with any errors that still exist (if any exist)
water gets into switches and motor windings and causes these codes.
I have seen it take days to completely dry out for them all to go away :o/
  • Posted 3 Nov 2014 22:34
  • Modified 3 Nov 2014 22:35 by poster
  • Reply by swoop223
Hi,
When is full lock on the left motor the truck doesnt drive revers.
When the lever is switched back the main switch goes out and appears error code 18.
When I start truck it drives forward when I let go and then press again gas pedal the error code 18appears.
Both motors left and right are correct.
Thanks in advance.
  • Posted 3 Nov 2014 20:34
  • Reply by marija_p
mprolic@hotmail.com
Hi Mate
Fault relates to right drive motor field circuit. Check field circuit if that checks ok its a good chance fault is in the H Bridge card.
Does the truck drive ok in both directions on full lock on the left motor?
  • Posted 31 Oct 2014 10:12
  • Reply by elektrodrive
enquiries@elektrodrive.co.uk
Hallo,
I have Caterpillar ep 16kt, serial number ET34A27543, year 2002.
The main problem is that forklift moves forward, but doesnt move back.When gas pedal is pressed again fall out all the functions of movement (forward/revers )and appears on the screen ERror 18.
What can be a problem?
Thank you in advance.
I really dont know what to do.
Dragan
  • Posted 30 Oct 2014 19:08
  • Reply by marija_p
mprolic@hotmail.com
Hello Thearaymondguy
Seems you are right.
We have error problem at display HS 5 or H5.
Do you know something more about this.
Do you mean on kyba logic card which is for example used at nissan forklifts?
Sorry if i am asking too much but do you know where is situated H bridge card?
Many thanks, Marko
  • Posted 15 Mar 2008 00:45
  • Reply by marko
  • Croatia
Do shorts to frame test prior to install of new logic card.
Code 60 is lack of communication between Dash and Logic Card.
Truck turns on, sees no comms, display reads Code 60.
Use part # on card to order new, this card is used in many many many applications.
Would not be surprised to see H-bridge card dead too.
  • Posted 23 Feb 2008 12:58
  • Reply by theraymondguy
Hello AndyPandy
offcurse everything is at one maschine
after soemody smart washed elektro forklift with miniwash
display started with 52, 53 and at the end number 60 is all the time there.
thnx marko
  • Posted 12 Feb 2008 06:34
  • Reply by marko
  • Croatia
Hello Marko
60 is a serial communication fault, faulty display unit, faulty wiring or logic card. 52 is a right hand speed sensor fault and 53 is a left hand speed sensor fault. If you are getting all these on one machine i would suggest looking at the main loom.
  • Posted 12 Feb 2008 05:46
  • Reply by AndyPandy
Hello AndyPandy
Do you know what is error 60, 53, 52?
100 times thanks.
Marko
  • Posted 11 Feb 2008 19:37
  • Reply by marko
  • Croatia
Thanks you a very much.
If you need some info for Still or jung let me know
  • Posted 15 Jan 2008 18:06
  • Reply by marko
  • Croatia
Hello Marko
If you remove the floor plate with the accelerator pedal on it, the pot is on the underside of the floor plate. The part number for the potentiometer is printed on the pot. If the new pot is not fitted in the correct position you will still get the 51 fault. i would just give the existing pot a slight twist before replacing it. Loosen the 2 screws and twist the pot a fraction and retry. You may find this is all you need to do.
  • Posted 15 Jan 2008 17:36
Hello AndyPandy
But something strange is going on with this forklift. Sometimes it turns off 10 times in minute
sometimes you can work wit it 3 hours (joust example)
Can you halp me where i can find this throttle pot, i want to make it right and fit new pot.
If you will be so kind little bit detailed explanation.
Thanks one more time
  • Posted 15 Jan 2008 08:21
  • Reply by marko
  • Croatia
Throttle pot adjustment. You can usually get rid of the error by very slightly rotating the pot. If this fails you will need to fit a new pot.
  • Posted 15 Jan 2008 03:11
Terberg YT182
Hangcha CPYD32XW71F-C
Flesherton, Ontario, Canada
edition #1229 - 8 May 2025
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
SMV (Konecranes) 16-1200C
Taylor XC300M
New - Sale & Hire
