Caterpillar E6000
I have an E6000 with a code 45. can anyone tell me what that is? Or where I can get or purchase a PDF MAnual that conatins a list of codes?
Thanks
  • Posted 17 Jul 2009 06:38
  • By boatnut
  • joined 17 Jul'09 - 3 messages
  • Alabama, United States
Correct, I have seen no Visual problems so far. But I will inspect closer Just to be sure. I will also list my E-mail adress...Thanks Again for all and any info on this subject.
  • Posted 17 Jul 2009 11:42
  • By boatnut
I should have noted that if anyone has the manual, they would need a method to contact you, so adding an e-mail address to your profile would be a good thing.
I also should note that this may well be a burnt cable at the controller or motor, as well as a possible wire connection not making good contact at the DSP card (or other spots), but I had figured (assumed) you would have seen the burnt cable before you wrote to this forum.
  • Posted 17 Jul 2009 09:51
Thanks fo rthe info..
  • Posted 17 Jul 2009 09:35
  • By boatnut
your local Cat Lift truck dealer (I think it is Thompson Lift Truck) should be pleased to order you the maintenance manual.
On your truck, code 45 is an "open in traction motor circuit". the checks for this is "non-trivial", and most likely best done by someone familiar with the controls of this type truck, most likely the Cat Lift truck dealer.
  • Posted 17 Jul 2009 08:07
Terberg RT403
SMV (Konecranes) 4531CC5
