Cat P5000
P5000 Cat with a K25 nissan LPG engine. While running engine it make a slapping or metal to metal ringing noise. I have removed PTO chain and ran the engine noise still there. I have replaced the timing chain , chain tensioner , and both gears. Noise is still there. Removed the oil pan and checked , no metal in the oil pan piston skirts ok ,cylinder walls look ok. no real end play in the crank shaft. Im at a loss guys. Has anyone had anything like this with these engines. Your help would be great , thanks
  • Posted 20 Jun 2011 10:47
  • By jnc1
  • joined 14 Nov'09 - 11 messages
  • Virginia, United States
Check your engine mounts and be sure you have rubber! One last thought here. Has the idle air volume learn been performed as this will also adjust the timing back to -0-/ base.
  • Posted 4 Apr 2014 11:24
  • Modified 4 Apr 2014 11:54 by poster
  • By RCAV8TOR
  • Alabama, United States
any luck finding noise, I have same issue
  • Posted 4 Apr 2014 08:33
  • By dhls
  • joined 20 Jan'12 - 10 messages
Starter motor with a loose or broken nose cone?????
  • Posted 23 Jun 2011 21:47
  • By Prentice
Exhaust pipe, muffler, torque convertor???
I guess me and Edward are working on it at the same time :-)
  • Posted 21 Jun 2011 09:30
  • Modified 21 Jun 2011 09:32 by poster
tried listening with a stethoscope? exhaust related? deep engine block? transmission flex plate? torque converter? equipped with under frame screen? does it change with mast tilt? does it change with engine speed or truck speed?
grasps at straws....
  • Posted 21 Jun 2011 09:29
  • Modified 21 Jun 2011 09:31 by poster
Yes I have.
  • Posted 21 Jun 2011 08:04
  • By jnc1
have you tried running it with the belts off? to see if the noise is from a fan or alt noise?
  • Posted 20 Jun 2011 20:14
Toyota 8FG25
Hangcha CPYD70XW24B-C
Flesherton, Ontario, Canada
Dallas, TX or Lexington, KY, United States
Orlando area, United States
Tacoma, WA, United States
Highland, IL, United States
