Cat/Mitsi - C5000 - AT9002927 Tran Slip
Customer says it does not go into drive first thing in the morning. after the unit warms up it gets better. Tourque, Clutch packs, solinoides???? Anyone have any trans issues with model
  • Posted 25 Feb 2012 04:14
  • By Prentice
awesome Prentice
i kinda figured thats what was going on since i've ran across this problem quite a bit and it can be mistaken for other things, even from some of our own guys.
Just remember since you have the inching cable loose you may want to go through the adjustment proceedure and reset the adjustment on that cable just to make sure its right after you reassemble it.
good job man!
  • Posted 3 Mar 2012 10:02
  • Modified 3 Mar 2012 10:03 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
You have to like this form......you guys hit the nail on the head.
ran pressure test found fwd/rev clutch at 30 -25 psi. removed inching cable and worked the inch/dump valve and it went to 150 psi. Parts are on order. Customer is smiling. Thanks for the great advice.
  • Posted 2 Mar 2012 04:34
  • By Prentice
in addition. if you over tighten the mounting bolts for the inching linkage you can effect the travel of the inching spool. Over tightening the bolts distorts the trans valve and can cause the spool to hang in the bore.
  • Posted 1 Mar 2012 02:18
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Nothing like alittle insite, good thinking Jplayer, or should I say, good remembering on the bulletin.
  • Posted 27 Feb 2012 23:30
  • By 7777
before you get carried away with replacing the transmission routine someone already mentioned the inching mechanism.
One common problem these units have had and there is a service bulletin out on this... the inching can affect the drive if that lever/pivot bracket is binding up. (yes the one on top of the transmission the cable hooks to that pushes on the inching spool )
i'd remove the cable and take it off the post and check the o-rings , replace if necessary and lube it up, reassemble it and then recheck. THEN if necessary run pressure checks. IF that lever is binding it will throw your pressure checks off.
Thanks and have a nice day!
  • Posted 27 Feb 2012 22:13
  • Modified 1 Mar 2012 09:31 by poster
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Sounds good.
Commanly what happens, the forklift is used like a track machine and operaters do alot of pushing of pallots in the forward motion. This will ware out the forward clutch packs and leave the reverse intacted. The only issue I dont understand is, when the machine gets hot, the pressures should drop as oil is bypassed in the packs. But I have seen it both ways, where at cold start, for some reason the oil pressure is not enough to operate the truck. Maybe its a weak trany pump or torque convertor, in which case both for and rev will be affected. Perhaps one direction more than the other due to pack ware.
  • Posted 26 Feb 2012 23:46
  • By 7777
In the shop now. Running Pressure tests. Let you know soon
  • Posted 26 Feb 2012 22:53
  • By Prentice
Does it go into reverse in the morning, and what happens when it works for about an hour?
  • Posted 25 Feb 2012 08:50
  • By 7777
Never run into any internal transmission issues,have had a few with the inching cable and brackets were binding some causing issues
  • Posted 25 Feb 2012 04:47
  • By kevin_t
Deborah Baker Deborah Baker
