cat m30d electric forkilift
guys, i have a md30 forklift and use it a few times a week. the battery is not great so i charge it the morning i use it and it works for the day or maybe 2 days, but limited use. I had some contacts stick, and i took them apart and cleaned them, when one was stuck it would move forward and the hydraulics would work, now after i cleaned them up it does nothing. when i turn key on one contact *** in, and the digital battery light flashes F and then nothing, turn the wheel and the motor doesnt start, nothing. al i did was unstuck on contact and filed it down to smooth it up.
ideas?
  • Posted 6 Jun 2013 05:57
  • By jake_p
  • joined 6 Jun'13 - 1 message
  • Maine, United States
on these trucks it is a single digit display
it can flash just an F or if there is another issue it may be an F & 2 or 3 or 4 etc. Now if it flashes numbers like 1, 2,... F then its a low battery issue. There is a difference, F and then a number or just an F indicates a component failure. scrolling numbers followed by an F indicates a low battery issue.
A flashing E would indicate no seat switch input.
If it is just flashing an F with no other numbers this indicates a logic board failure.
You may want to double check your connections, wiring around the board. Since you were working on one of the contactors you may have inadvertantly pulled a wire loose or connected one up incorrectly? Also since you cleaned those contacts hopefully you didnt file them off? maybe you filed them too much and now have no contact? If this was the line contactor try manually pushing it in when you turn on the truck and see if that makes a difference. By default when the truck is activated the line contactor should pull in, then the steer contactor and a few seconds later the steer contactor will drop out. Of course if there is a logic circuit problem it may not pass the self test on start up.
Does the truck have the decal under the hood that shows a diagram of components and how they are laid out along with a self test diagram of instructions on how to run the self test? Most of these trucks had that unless at some point it came off or was removed?
There is also a page or 2 in the front of the troubleshooting manual specifically directed towards battery care and troubleshooting frame grounds etc, you should re-check the battery and make sure it reads no less than 33.1v for a 36v battery or 44.2v for a 48v battery. So a per cell check and each cell should read around 1.95v to 2.12v. If any cells read below 1.95v the battery should be charged or repaired.
hope this helps
  • Posted 6 Jun 2013 20:50
  • Modified 6 Jun 2013 20:56 by poster
Jake,
Are you sure it is a flashing F and not a flashing E? Was it the line contactor that was stuck? When you turn the key on does the line contactor energize and then drop out? If the code is an F is there a number after it? For example F-3. If it is a flashing E that is an open seat switch.
  • Posted 6 Jun 2013 12:12
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Aichi SR10C1SM
Enforcer FD50T-MMA
Muncie, IN, United States
Aichi SR10C1SM
Enforcer FD50T-MMA
Deborah Baker Deborah Baker
Aichi SR10C1SM
Enforcer FD50T-MMA
