CAT M#MC60DP S# 7BK00157 - Flashing F-1
Hello all,
The unit has hydraulics - slow speed when in froward/reverse - full throttle pops the code F - 1 (flashing) - battery level is at 9 on the dash - 37 -36 volts at battery and panel - specific gravity is good to fair - the steer/hyd motor sounds like its running on low volts ( barely turning) but has full hydraulic functions
Has anyone had this problem?? looking for an area to start -
  • Posted 30 Sep 2009 04:36
  • Discussion started by Prentice
You called it electrodrive, cleaned entire unit and found the bottom of the throttle controller had been missing ( return spring busted out) Code E - Installed new controller and drives great. one small problem the steering/hydraulic motor seems to turn very slowly when unit is idle. Is this normal???
  • Posted 6 Oct 2009 22:01
  • Reply by Prentice
Thanks elektrodrive, the throttle assembly is in poor condition.The whole unit is very dirty.I will sart there and let you know.
  • Posted 1 Oct 2009 22:46
  • Reply by Prentice
Not sure about this particular model, but on some of the cat trucks the F1 fault code is related to the foot pedla being out of adjustment. Which makes sense with your slow speed issue and only comming up when fully depressed. Does this truck have one of those foot pedals with opto led circuits internally? If so it may require a blow out just a clean does the job sometimes.
  • Posted 1 Oct 2009 03:17
  • Modified 1 Oct 2009 03:18 by poster
  • Reply by elektrodrive
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Hangcha 80XENS
Flesherton, Ontario, Canada
Hoist Liftruck P360-48
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
edition #1229 - 8 May 2025
