Cat GP18N (2004) Nissan K21 engine settings
Hi
Can any one supply the Cylinder head Torque settings and valve clearances
Thanks
  • Posted 16 Jul 2012 04:22
  • By nigel_p
  • joined 8 Jul'10 - 20 messages
  • Worcestershire, United Kingdom
I had a similar problem from Jungheinrich.
Nissan Motor.
VN coil was located in the distributor.
1 of 2 coils burnt
Others got in the mail
  • Posted 5 Jan 2013 18:44
  • By geroj
  • joined 21 Feb'10 - 262 messages
  • Krivan, Slovakia
The first thing to do is adjust the intake and exhaust valve. If this is a k21, with 4 ignition coils, you can unplug them and swap the coils around. If your spark plugs are worn out, the coils will go bad.
  • Posted 4 Jan 2013 11:20
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Hi!
I have a problem with engine Nissan K21072686!It is seems like 2. and 3. piston doesnt work,I replaced control valve, cap an electronic, but again the 2. piston like it doesn't work???!!
If You have manual for this engine, it would be great!Just to see what can be wrong...i was talking with many mechanics , electronics ,but i didn't solved problem!
Best regards!
Dragan
  • Posted 25 Dec 2012 04:19
  • By marija_p
  • joined 27 Nov'10 - 33 messages
  • bosna i hercegovina, Bosnia And Herzegovina
mprolic@hotmail.com
head bolts: 51 ft lbs
Valve lash.015 with engine hot
  • Posted 16 Jul 2012 06:04
  • By kevin_t
Muncie, IN, United States
Deborah Baker Deborah Baker
