Cat Lift Trucks (& Caterpillar) GC25K OR GP25K:
CAT GC25 smoking
I have a 2004 CAT GC25 blowing white smoke out the tail pipe. The head gasket is new and compression is good. is it possible coolant is getting in the fuel system?
  • Posted 18 Oct 2011 00:40
  • Discussion started by ed_h
We had a tech powere wash a unit and got some water up the tail pipe. could be water or condensation in the exhaust
  • Posted 18 Oct 2011 22:31
  • Reply by Prentice
serial number and/ engine size model might be nice to be sure we get the right info,
the mitsu 4g64/ 4g65 have been known to have a corrosion in the part of the cooling system that runs under the intake manifold. you may also have bad valve seals or rings.
are you loosing coolant or oil?
  • Posted 18 Oct 2011 20:15
  • Reply by edward_t
MAXAM Tire, Inc.
Louisville, KY, United States
Dubuque, IA, United States
edition #1228 - 1 May 2025
