CAT GC25 smoking
I have a 2004 CAT GC25 blowing white smoke out the tail pipe. The head gasket is new and compression is good. is it possible coolant is getting in the fuel system?
  • Posted 18 Oct 2011 00:40
  • By ed_h
  • joined 26 Mar'11 - 13 messages
We had a tech powere wash a unit and got some water up the tail pipe. could be water or condensation in the exhaust
  • Posted 18 Oct 2011 22:31
  • By Prentice
serial number and/ engine size model might be nice to be sure we get the right info,
the mitsu 4g64/ 4g65 have been known to have a corrosion in the part of the cooling system that runs under the intake manifold. you may also have bad valve seals or rings.
are you loosing coolant or oil?
  • Posted 18 Oct 2011 20:15
Taylor TXB180S
Toyota 3FD100
August 19-21, 2026 - Bangkok, Thailand
November 18-19, 2026 - Singapore, Singapore
November 25-26, 2026 - Budapest, Hungary
Chandler, United States
Philadephia, PA, United States
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
