cat. g5000 code 27. n all indicator lights flshing
cat c5000 with code e-27 showing. truck start. running like misfire. i did changed sparkplug n check all hv good spark.
got 12v. does any coil pack need change?
anyone can give me any idea to clear these code n flashing lights. or still hv other problem need done? plz thx all
  • Posted 27 Aug 2009 00:13
  • Modified 27 Aug 2009 02:00 by poster
  • By jonip
  • joined 4 May'09 - 11 messages
spark plugs (usually the most common cause)
POS Sensor
bad wiring at coil packs (connectors)
anything that faults in the ignition circuit can trigger this code
to clear this code use diagnoser or do the pedal dance
  • Posted 5 Sep 2012 20:26
Truck would also code 27 in one of the coil packs was dead.
  • Posted 5 Sep 2012 11:34
  • By LTRM
  • joined 26 Jan'12 - 161 messages
  • Illinois, United States
Code E-27 is refered to the ckp(crankshaft position sensor)
but this code appear when you are instaling bad spark plugs.
Try with original nissan plugas.
I hope this help.
  • Posted 5 Sep 2012 09:52
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
i have the same please any help
  • Posted 5 Sep 2012 07:35
  • By JHpantaleon
  • joined 26 Jun'10 - 13 messages
  • distrito, Dominican Republic
Toyota 8FG25
Taylor TX330S
USD159,500
Zhejiang UN Forklift Co., Ltd
Toyota 8FG25
Taylor TX330S
USD159,500
Muncie, IN, United States
