Cat Forklift ep16k
showing no display but the led is on. and in the right side of the display its showing dd. before its working fine and its showing a couple of error codes. but then when i turn it off then on. the problem get worse. i dont know what codes or foult im getting. it show only "dd" on the right side where the speed meter is displayed.
  • Posted 27 Feb 2016 18:24
  • By justin_d
  • joined 27 Feb'16 - 28 messages
  • RIYADH, SAUDI ARABIA, Saudi Arabia
Thankyou verymuch for the reply. it really help me. i find the DRS switch at the rear and buttom of the logic card. i remember that i set it to S and forgot to bring back to R. now im getting a normal display. like i said last time before im getting a couple of Error Code. 30 and 54.
i have manual for this but i really dnt know what to check. in error "30" it says "Pump Motor, Foulty Circuit"
in the error "54" it says FC Lever Abnormality.
  • Posted 3 Mar 2016 18:26
  • By justin_d
On your logic card you have a small toggle switch with three positions. It is called the DRS switch. The switch must have been moved to the D or diagnostic position. It will display dd when you close the seat switch and turn on the key. The S or set-up position is for set up options. You should make sure it is in the center R position that is for run. Hope this helps.
  • Posted 1 Mar 2016 16:00
  • By shovel_fx
  • joined 11 Mar'12 - 41 messages
  • Illinois, United States
