cat ep30k-pac error code 01
what is the meaning
  • Posted 18 Jul 2012 22:06
  • By emma
  • joined 13 Apr'10 - 3 messages
  • lagos, Nigeria
SRO = Static Return to Off
this circuit monitors inputs from the truck
seat switch
directional control
accelerator control
etc
if you are not getting any input to activate the system the truck will turn itself off or go into soft-off mode. Most often displaying a code such as the 01 you see. In alot of cases the 01 means seat switch input but in this trucks case i'm not sure because in the code list there is no 01 code.
  • Posted 21 Jul 2012 06:16
  • By Jplayer
John Player Jr
_________________
LiftOne, LLC
Charlotte, NC
Email: jplayer@liftone.net
Thank you so much,what's "sro" and please explain in details.again thanks for your post. jim i discovered how to fix error 60 serial comm problem on logic card,it is power voltage reg ic si-3152.
  • Posted 21 Jul 2012 05:46
  • By emma
  • lagos, Nigeria
emma
Check your SRO. Check seat swith, dir. control, ect.
  • Posted 19 Jul 2012 22:00
  • By jim_i
  • joined 19 Jul'12 - 2 messages
  • Manitoba, Canada
Are you sure the code is 01?
  • Posted 19 Jul 2012 07:10
  • By AndyPandy
Deborah Baker Deborah Baker
ROYPOW
