cat ep lift truck steering issue
I have a cat electric model ep s.n. 6mm00448 and the if i try to go forward one wheel spins forward and the other back-words, but reverse works OK, is there some kind of sensor that needs adjusting or ??.
  • Posted 5 May 2009 09:31
  • Discussion started by kurt_s
  • Illinois, United States
if the contactor are your probleme your bether to put contactor assembly. Kits are pain in the
.... you need shims (bad experience).
  • Posted 7 May 2009 08:07
  • Reply by yan_l
  • Quebec, Canada
lamex.lift@yahoo.ca
on some of the three wheel nissans there is a pot above the back wheel which controls the contactors. i had a faulty pot which caused this fault. but like i said it was a nissan.
  • Posted 6 May 2009 03:19
  • Reply by uplift
  • lincoln, United Kingdom
upliftuk@gmail*com (*=.)
Yes it is a three wheel truck and what your telling me makes sense, Ill check the contactors. Thanks!!
  • Posted 6 May 2009 01:50
  • Reply by kurt_s
Is it a three wheel truck?
On the old type three wheeled Cat EP forklifts there are two changeover direction contactors one for each drive motor. One is normally in forward and the other is normally in reverse, so if the contactor that is normally closed in reverse is not operating then that motor will only run in reverse.
Shane
  • Posted 5 May 2009 20:15
  • Reply by controlelectric
  • Shropshire, United Kingdom
edition #1235 - 19 June 2025
Toyota 8FGU25
Flesherton, Ontario, Canada
Mafi MT25
Mafi MT25 2008
