CAT EP 16KT
I HAVE A PROBLEM WITH CAT EP16KT , ITS SHOWING ERROR 30 ON DISPLAY
  • Posted 29 Dec 2012 17:12
  • Discussion started by thilakan_k
  • DUBAI, United Arab Emirates
yes there is a fairly wide range of issues that can trigger this code. The most common one i've ran across though is the drive board causing problems. Pull the logic card and check the drive board which is underneath the logic. It will have several large diodes on it, check those diodes for proper continuity and/or burning.
If no issues found there then you will have to go through the rest of those listed problems to find the cause of the voltage irregularity thats triggering this code.
and by the way, this thread is in the wrong section ;o)
  • Posted 30 Dec 2012 21:30
  • Modified 30 Dec 2012 21:40 by poster
  • Reply by swoop223
This code is produced by a faulty Pump motor circuit, line contactor, faulty D1P diode or faulty pump motor wiring. it could also involve a faulty head capacitor, T1P IGBT, current sensor Logic card or drive board.
If you post your email in a broken form I will send you some information
  • Posted 30 Dec 2012 00:38
  • Reply by AndyPandy
edition #1228 - 1 May 2025
