CAT E 6000 Code 65
Serial A4EC-341063.
Can someone describe this error code to fix it.
Thanks for your help.
  • Posted 24 Apr 2015 04:21
  • By pastrana_j
  • joined 3 Aug'10 - 103 messages
  • Puebla, Mexico
E1200? or E12000?
on the E12000 the codes:
-64 means the line driver input (P2-17) is less that 12% of battery volts.
-65 means the line coil is too high during the run mode.
i would check the line contactor.
check the coil resistance, should measure 59ohm for 36/48v trucks, 161ohm for 80v trucks. also check the signal on that wire 17 on P2 connector and make sure there is a signal when the truck is turned on.
if all that checks out ok then you have a bad controller unit.
  • Posted 7 Oct 2023 08:13
Swoop modelE1200 has a 64 and 65 code can you point that direction
Tanks
  • Posted 7 Oct 2023 07:18
  • By JKPAINTER
  • joined 26 Jul'17 - 73 messages
DTC 65
Pump Inverter Fault
see your mail for information on how to troubleshoot this
  • Posted 24 Apr 2015 21:59
Aichi RX07B
Terberg RT223
Tampa Florida, United States
edition #1289 - 9 July 2026
In this week’s Forkliftaction News , we continue our coverage of CeMAT Australia with a report on how the lack of local after-sales support and service is hurting new foreign entrants into the Australian market... Continue reading
Cameron Paxton Cameron Paxton
President and chief executive officer, Toyota Material Handling Australia (TMHA)
President, Doosan Bobcat North America
Chairman of the board of directors, Manitou Group
Sales manager for the UK & Ireland, BSL Battery
