cat dp30k transmmission
can anyone help me with testing procedure/pressures for transmission/torque convertor on a dp30k ,have one that is slow on initial drive and gets worst as truck is used.
  • Posted 16 May 2013 21:41
  • By markg
  • joined 27 Oct'09 - 57 messages
  • n lincs, United Kingdom
thanks mark
the ET designation makes this a euro model but its the same as the AT. What i'm sending you will show metric and US standards in the tables so you should be fine with this.
  • Posted 18 May 2013 23:30
ok
ser no et14c-46514
mgplantservices at hotmail dot co dot uk
  • Posted 18 May 2013 18:03
  • By markg
hey mark, the site automatically removes weblinks and email addy's out of posts. You can alter the email address by spelling it out like youremail dot com or you can also go into your profile and adding it into your signature, it should work that way also.
  • Posted 17 May 2013 20:44
ser no et14c-46514
[email address removed]
thanks.
  • Posted 17 May 2013 16:23
  • By markg
i need 2 things
1- serial number of lift
2- your email address
those pressures prentice posted are not correct, close though ;o)
  • Posted 17 May 2013 06:24
I had a unit last year with the same problem
Pressure tests in PSI
Main 142.2 to 177.8
Clutch 142.2 to 177.8
Torque 14.2 to 71.1
Lube 7.11 to 72.7
Test run at 1600 RPM
We found low clutch pressure, pull trans apart and found broken Snap rings on the Fwd/Rev Clutch packs. Hope this helps.
  • Posted 17 May 2013 05:55
  • By Prentice
seems to be both, cheers
  • Posted 16 May 2013 22:15
  • By markg
does this happen in both directions? fwd and rev?
  • Posted 16 May 2013 22:11
Libiao Robotics
Deborah Baker Deborah Baker
Libiao Robotics
Muncie, IN, United States
