Cascade Bar Clamp 25D-BAS
Hi evryone. I would appreciate suggestions regarding a continuous problem we've been seing with a Cascade bar clamp that seems to be loosing pressure and ends up droping the load while carrying it. We already regulated the press valve all the way, but problem still persist. cascade unit is brand new.
Any suggestions on what to do will be very much apprecaited.
Thnx,
OB1
  • Posted 11 Mar 2012 02:49
  • By ob1kenobi
  • joined 22 Nov'10 - 153 messages
  • SAN P.SULA, Honduras
Cheers!
Thanks rogeriwt!
  • Posted 12 Mar 2012 00:47
  • Modified 12 Mar 2012 00:50 by poster
  • By ob1kenobi
Cheers!
Thanks mrfixit. We'll look into this.
  • Posted 12 Mar 2012 00:46
  • Modified 12 Mar 2012 00:49 by poster
  • By ob1kenobi
Cheers!
krzysztof
My email is obandy01 at hotmail
  • By ob1kenobi
mrfixit had it, lock valve. It holds the pressure on the clamp at a set value. I know cascade has a parameter used to set these with and the lock valve isolates the clamp form the rest of the trucks hydraulics.
  • Posted 11 Mar 2012 05:19
  • By rogeriwt
Hi
Your a-mail to send data
krzysztof
  • Posted 11 Mar 2012 04:51
  • By krzysztof_k
  • joined 2 Feb'11 - 129 messages
  • śląśk, Poland
Lock valve? There is a valve at the end of each hyd cylinder in the clamp. These have already been regulated to max press. Customer is lifting cloth packages.
  • Posted 11 Mar 2012 03:53
  • By ob1kenobi
Isn't there a lock valve mounted on the clamp? What are you picking up?
  • Posted 11 Mar 2012 03:38
  • Modified 11 Mar 2012 03:41 by poster
Hi rogeriwt. The control valve is new. There is no flow valve.
  • Posted 11 Mar 2012 03:27
  • By ob1kenobi
I am assuming that you check the control valve for internal leakage. Is there a flow valve for the clamp being used?
  • Posted 11 Mar 2012 03:04
  • By rogeriwt
Muncie, IN, United States
