c3000 missing
i have a cat c3000 lift thats a 2005 with 11000 hours. i pulled the wires on the (plugs) and the 3rd one has no effect. its running rough and all the lights on dash are flashing.is this normally the plug or coils.i dont know much about this new electronic engines. thanks for any help
  • Posted 7 Jan 2010 11:42
  • By jshesson
  • joined 7 Jan'10 - 1 message
  • Tennessee, United States
Well your this far in.Swap coil packs assuming new plugs have been installed.Did the miss swap?If it did order yourself a new coil.You might want to be careful pulling plugs if they haven't been done.They corrode on the end and bring threads with it.If their stuck break them lose then apply penetrating oil,run them back in apply more let set work with them dont just go gung ho
  • Posted 21 Jan 2010 23:00
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
have the spark plugs ever been changed? At a minimum the plugs should be inspected every 200 hours and replaced every 3,600 hours or 18 months. Probably should contact your CAT Lift Dealer. Since you removed harnesses from coil packs, fault codes have been set.
  • Posted 8 Jan 2010 05:39
  • By carl_v
  • joined 12 Oct'07 - 76 messages
Oxford Ct, United States
Terberg RT223
SMV (Konecranes) 16-1200C
Zhejiang UN Forklift Co., Ltd
Esie Cortez Esie Cortez
