BT SWE 160D ERROR C28
Hello, We have a problem with the truck BT SWE 160D No. 722803. After connecting the power supply (battery) starts to heat up PTC resistor located on the contacts of the main contactor K10. When you enter the boot codes appear in the display error C28, not attached to the main contactor. Emergency switch, power cords, fuses are intact. After disconnecting the cables from the motor drive, the controller starts normally, does not display any error, the contactor shall be attached. The engine also does not break (shorting). Please help because no one with whom I spoke, did not meet with this type of defect.
  • Posted 7 Mar 2014 20:36
  • By blazej_f
  • joined 6 Mar'14 - 5 messages
  • Pomorskie, Poland
I checked on three different batteries, replaced the contacts of contactors (main and pump) for new motor insulation when measuring 500v: field about 2GΩ; rotor about 5MΩ that is very good. Curtis? Right here is something I do not agree. 1) I plug the batteries, starts to heat up PTC resistor, with Curtis on the main contactor out -24V, after entering the codes C28 error occurs. 2) Disconnect the A2 cable (-M) Curtis-motor drive, plug in the battery, enter the code, the truck passes the self-test, all functions operate outside the ride (cable disconnected) after connecting cable A2 to -M carriage ride begins and so on until the re-disconnection batteries.
  • Posted 8 Mar 2014 16:19
  • By blazej_f
  • Pomorskie, Poland
First check if battery is OK at full charge (density and cell voltage), welded contacs in main or pump contactors, check motor isulation or defect in curtis controller.
Regards.
  • Posted 8 Mar 2014 08:01
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Toyota launches three new stackers Columbus, IN, United States
Crown WP302020
Taylor T650L
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
