bt sl 200
Hi guys I have a BT sl 2.0 ride on pallet truck
Turn on thg ignition and it powers up.step on the floor switch and the line contactor closes at this point you have lift function steer function. select either fwd or rev the machine cutout and displays fault code E 102.
any ideas or if anyone had a manual that would me great
thanks
  • Posted 11 Sep 2012 01:57
  • By Mag1
  • joined 24 Feb'06 - 25 messages
  • CO DUBLIN, Ireland
These SL 2.0's are to prehistoric to use the BT CAN service key.
All the adjustments are done with the 3 push buttons on the A5 card ( big silver card ) & also the Curtis hand held programer on the A1 card ( black traction box )
A5 card is in overall charge of the truck BUT that feeds certain information on to the A1 card which is basically in charge of traction & brake.
Ill email you the info.
  • Posted 11 Sep 2012 18:38
  • By Forkingabout
  • england, United Kingdom
thanks for the quick response i will check it out in the morning
when you say the outputs are they from the drive controller or the silver box above the drive controller.this is a non canbus key model. again thanks for the help
  • Posted 11 Sep 2012 07:02
  • By Mag1
E102 = One of the outputs has short circuited to earth.
If the fault occurs on the outputs for driving/brakes the drive is cut.
If the fault occurs on the outputs for hydraulic pump the lift is blocked.
If the fault occurs on the outputs of other hydraulic functions lifting and lowering are blocked.
  • Posted 11 Sep 2012 03:23
  • By Forkingabout
Terberg YT222
Morooka MFD20
Deborah Baker Deborah Baker
