BT OM 0.85 fault code c027
One of our stackers shows this fault code.
But right now it seems to work as normal.
So does anyone know what this code means?
  • Posted 22 Jun 2009 21:23
  • By MT26
  • joined 22 Jun'09 - 3 messages
  • Møre og Romsdal, Norway
Hi MT
Im pleased i could help you and youve repaired the fault...
  • Posted 4 Jul 2009 04:09
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
Thank you very much. Found a defekt socket plug, and we are going to change that.
Altso if possible, have anyone a complete fault code list that I can have?
  • Posted 1 Jul 2009 17:43
  • By MT26
Hi MT26 fault code c027 relates to the battery measuring wires.
these wires run along the battery cables, check these for breakage. If you replace the broken wire make sure you replace with same.....
Let me know how you get on or if you need anymore info
  • Posted 24 Jun 2009 02:12
  • Modified 24 Jun 2009 02:14 by poster
  • By powerlifter
Noblelift
