BT ERROR CODE 3.564
BT LWE180 error 3.564 can not find this error code in my book Does anyone know what this code is?
  • Posted 19 Aug 2022 01:25
  • Modified 19 Aug 2022 01:57 by poster
  • Discussion started by richard_m
  • lancashire, United Kingdom
richardsforklifts @gmail.com
All depends which BT truck you have i suppoose :)
3:564 Low current
Allt stoppas direkt, parkeringsbroms aktiveras och huvudkontaktor öppnas.
The amperage is below the limit
value 100mA on the output to
brake (Q10)
* Low power consumption
or break
1) Check wiring and component after the break
Disconnect the battery
Visually check the wiring
harness
Using instruments, check
that there is no break in
any wire
Check the Ohms and the
Amperes of the component, compare them to the
setpoint values, and replace the unit if they are
outside the accepted
range.
Reconnect the battery.
Measure and check the
voltage for the activated
functions
  • Posted 19 Aug 2022 01:31
  • Reply by andrew_k
  • England, United Kingdom
edition #1234 - 12 June 2025
Your Focus
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
