Linde (& Baker) H25D 392:
Brakes stuck on
Truck tries to drive but feels like brakes are stuck on, No error codes.
Any ideas please
Thanks
  • Posted 20 Jul 2022 03:00
  • Discussion started by andrew_k
  • England, United Kingdom
according to the 393-02 series (not sure but the 392 may be the same) but the brake system uses a brake valve operated by 2 switches. One of those may have been stuck or it could just be out of adjustment just enough to cause an intermittant problem.
I thought it may have been frozen up but 40deg isn't enough to freeze it up.
Plus Linde is fairly adement on having heaters located near switches to keep that from happening. (not all trucks have heaters but quite a few do).
I would double check those switches adjustments, make sure they are not dirty.
  • Posted 24 Jul 2022 07:00
  • Modified 24 Jul 2022 07:02 by poster
  • Reply by swoop223
Hi Michel. I went back to the truck the following day and it had fixed itself. Im blaming the 40 degrees weather lol. Thanks
  • Posted 23 Jul 2022 20:20
  • Reply by andrew_k
what is you brake presure ???????????
  • Posted 23 Jul 2022 04:33
  • Reply by michel_v
  • noord holland, Netherlands
Hyster
MAXAM Tire, Inc.
Johnston, IA, United States
Jefferson, WI, United States
St. Louis, MO, United States
