Blowing fuses Need HELP
So my Hyster 50xt keeps blowing the ign +1 fuse and I can't find out why. When the fuse blows all electrical power is gone but if you press the gas the engine is still running and will rev up. I changed the ignition switch and it also has a new starter. The problem didn't start until I replaced the starter. I have taken the new starter off and reinstalled it to make sure I installed it correctly and the problem is still happening. It is completely random when it does happen. So sometimes it will drive for a whole day and wont blow the fuse and the next day he starts it and it will blow the fuse.
  • Posted 13 Jun 2024 00:30
  • By Andrew_Fishback
  • joined 3 Apr'24 - 2 messages
  • Utah, United States
Andrew F.
Strobe light power wires were pinched between the plastic molding and frame Shorting out and blowing the fuse ign+1. The blown fuse caused a fault 522760-4. Fork would start, move even tilt, but would not lift. Had 1 driver who didn't think they needed to open the overhead door all the way. wacked the strobe. No noticeable damage, but just enough to move the bracket and pinch the wires behind the plastic cover that goes across the top between the 2 side lights. Removed the cover (3) 10 mil bolts and repaired the wire. Notched the plastic to allow for more clearance between the frame and plastic trim.
  • Posted 21 Feb 2026 13:21
  • By matt_capo
  • joined 21 Feb'26 - 1 message
  • nj, United States
Check wiring around starter for any sign of wear etc since it started after replacement of starter also look at where wiring for starter goes down from harness when you pulled on wires they may have gotten caught or rubbing engine
  • Posted 27 Jun 2024 07:29
  • By John_Bradley
  • joined 10 Aug'22 - 311 messages
Jb69
Andrew,
Since this only happens every so often, suspect you have a bad wire rubbing frame. First remove both front turn signal light if you have them. If fuse stops blowing, check light harness. If that doesn't work, unplug the strobe light and try again. Good Luck.
  • Posted 26 Jun 2024 02:03
  • By Fishmech
  • Virginia, United States
Tusk 350CGH20
Terberg RT223
edition #1301 - 1 October 2026
Forkliftaction News is excited to launch our Big Picture Interviews. In this thought-provoking series, we ask industry leaders for their insights on current market dynamics. In this week’s interview , Ralph Cox, Toyota Material Handling Europe’s SVP market operations, talks about why lean manufacturing and automation go hand-in-hand. Keep an eye out for the fortnightly interviews... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
