Toyota FGCU18:
Blowing FTS fuse 7.5
Good morning I have a 8FGCU18 SN#40076 in the shop and out of the blue it starting blowing the FTS 7.5 amp fuse when shifted into reverse it does not blow when shifted into forward just reverse and of course will not travel after blowing fuse anyone ran across this issue and also what else is in the loop with the FTS circuit
Thank you in advance
  • Posted 15 Feb 2022 02:36
  • Modified 15 Feb 2022 02:37 by poster
  • Discussion started by TIMBO
Thank you blue lights have been added I will check
Thanks
  • Posted 15 Feb 2022 06:24
  • Reply by TIMBO
Reverse circuit is back up alarm, reverse light. Any blue light added? The direction switch is sealed up in the column. Powers the 3 things as mentioned. Possibly a wire rubbed through Should be harness connectors behind the vaporizer for all that. Can unplug there and isolate the whole top side.
  • Posted 15 Feb 2022 06:12
  • Reply by ron_k
  • North Dakota, United States
4kliftman
Thank you that is where I am concentrating on now I checked the F & R switch and unplugged the solenoids and still blowing I am looking into that area now the light bar has been removed at some point do you know if anything else is in that loop
  • Posted 15 Feb 2022 05:46
  • Reply by TIMBO
Check your backup alarm and associated items for reverse circuit. Any damages to light bar etc.
  • Posted 15 Feb 2022 05:39
  • Reply by ron_k
4kliftman
Louisville, KY, United States
Dubuque, IA, United States
