Battery will not charge - Lights flashing.
So one of the employees forgot to turn off the forklift (Hyster W30ZA2 Pallet Stacker) and left the key in the on position over the weekend.
When I came in and noticed the battery was dead, I turned the key to the off position and plugged it into the extension cord after doing the usual cable switch.
After about 10 minutes of charging noise, 3 lights come on.
1 SOLID Wet & AGM Light (Yellow)
Flashing 30 and 90 % charge indicators.
Any idea what it means? If they are dead batteries, how can I access the battery compartment? Do you need any equipment to get the batteries out?
I'd like to get the batteries out so I can charge them individually to see if there is a bad one. I suppose it could be other things also, maybe someone can help me or lead me in a direction.
Thank you!
  • Posted 14 Jul 2021 03:36
  • By Leonard_Smith
  • joined 14 Jul'21 - 1 message
  • Washington, United States
Leonard,
Does the lift have an onboard charger? If so, that is what we call a battery pack. The whole pack would need to be removed from the lift. Then you have access to all batteries. Some stackers use an industrial battery and have a separate charger mounted on the wall. Serial# would help. Unfortunately, different battery configurations can be installed.
  • Posted 24 Jul 2021 05:35
  • By Fishmech
  • Virginia, United States
