Battery replacement and Charging
Hi,
So I decided to experiment and order a Chinese electric forklift, 1.5T, 3m.
As anticipated ran into problems. The 5 x 12 @ 150 AH batteries upon arrival would not hold the charge and went bad. Forklift works fine.
I am looking to replace these batteries.
The questions are:
1. Should I stick with 12V @150 AH \lead Acid batteries or can I use Lithium LiFePO4 instead? Pros and cons?
2. When Charging these batteries, am I better off charging each battery individually using a multiple charging system "or" is ok to charge all 5 batteries in series?
Currently they are wired in series to give me 48V, but I think series charge will not charge each battery properly and may reduce the life of the batteries.
Any advice on that?
Thanks for your help in advance.
  • Posted 5 Dec 2024 07:43
  • By Asim_Hasan
  • joined 5 Dec'24 - 2 messages
  • Illinois, United States
Slick Robotics
Any Takers?
  • Posted 6 Dec 2024 06:17
  • By Asim_Hasan
Slick Robotics
