Battery not being seen by computer
Had a e-24 code. Appeared wear was the issue. Adjusted throttle sensor. Did not know how to clear code. With unit in off position took ground wire off battery waited. Put back on. Code and check engine light are gone but now showing pic of battery like It's not seeing it.
  • Posted 23 Apr 2020 02:30
  • By Jeff_Sinarle
  • joined 23 Apr'20 - 1 message
  • Oregon, United States
Jeff Sinarle
Thanks for this informations..
  • Posted 27 Apr 2020 18:22
  • By Nicole_Lecompte
  • joined 29 Mar'20 - 2 messages
  • United Arab Emirates
Are you looking for affordable fit out company in Dubai? At Fitoutconcepts,
E24 is your accelerator pedal position sensor,
E23 is throttle sensor.
Is there a battery fluid sensor on the battery, maybe you broke the wire.
  • Posted 24 Apr 2020 06:20
  • Modified 24 Apr 2020 06:56 by poster
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
