Bad LP fuel destroying the regulator
I have a customer with a small fleet of 8FGCU32s. Over the past few days, every one of the LP regulators have failed. To be more specific, they do not have any output. Even when a new regulator is put on, it lasts about 1 or 2 days and has the same failure.
Each regulator is completely dry inside meaning no oil buildup or residue. The one thing in common with every lift is the fuel supply.
The LP vendor denies fault but it can only be the fuel. What would cause the fuel to do this?
  • Posted 5 Jun 2018 08:47
  • Modified 5 Jun 2018 08:48 by poster
  • By KUSA
  • joined 27 Mar'15 - 12 messages
We have had some issues with propane also, but our problem is blown diaphragms. Your problem is odd. If passages are getting plugged it would have to be a solid contaminate or a chemical reaction causing a plug. Have you torn apart a regulator to see if you can find the problem?
  • Posted 5 Jun 2018 23:51
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
There is liquid fuel to the regulator but nothing coming out. Every regulator in this account is failing. The regulator is replaced and runs great for a day or two and then fails.
There is something wrong with the LPG, perhaps and additive or improper blend of fuels. The fuel leaves no oily buildup like normal fuel. Perhaps it has too much butane or propylene. I've never had this issue before in 20 years.
  • Posted 5 Jun 2018 22:52
  • By KUSA
First you need to find out why there is no fuel delivery. You have to start at the tank connector and work your way to the regulator. Do you have fuel at the regulator?
  • Posted 5 Jun 2018 22:19
  • By BREWSKI
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
