Back alarm
I replaced the directional switch in the column, and for some reason the back alarm is staying on all the time, when key and seat switch is on, I've checked the contactor, and wiring, the wire to the back alarm is 0 ohms to the key switch, checked and rechecked the wiring on the direction switches, I.m wondering if it is programmable or if I've actually missed something, I have 2 of these in NS and 0 info, any help?
  • Posted 26 Oct 2009 21:52
  • By Barfly_olaf
  • joined 10 Oct'09 - 81 messages
  • Nova Scotia, Canada
I owe you some Canadian Beer, right side switches were up side down, guess my little map didnt help me, rewired and works great, thanks
  • Posted 29 Oct 2009 08:52
  • By Barfly_olaf
Yes rev lights are on and also rear marker lights on dim, dont know if the same problem, will recheck my wiring, but fwd and rev are fine, thankks, will update.
  • Posted 27 Oct 2009 23:21
  • By Barfly_olaf
Are the reverse lights on too? Check K2 relay. (swap with K1 for test). No pinched wiring behind assembly? column harness o.k? Wiring if your facing dir.control assy would be yellow on left rear top switch. black on left rear bottom switch. 2939 on left front bottom switch. 2938 right front on bottom switch. and 2937 on right rear bottom switch. 2940 on right rear top switch looped to 2937. whew!!! let us know!!
  • Posted 27 Oct 2009 11:11
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
Toyota 3FD100
SMV (Konecranes) 20-1200B
ROYPOW
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
