Auxillary wiring?
Hi all,
My reach has never worked on my lift. I went to see if I could fix it and after much mucking about I've determined that it is either wired incorrectly or that the diode pack (Raymond Part # 154-010-244) is bad. I was hoping that someone would have a wiring diagram so that I can check it. I'm also wondering what the point of the "Diode Pack" is.
Thanks in advance,
Corey
  • Posted 16 Feb 2013 09:57
  • By CoreyB
  • joined 16 Feb'13 - 1 message
  • Colorado, United States
well first thing that comes to mind is the wiring in the mast and pantograph like stam suggested, this generally is the most common cause of function failure in a reach truck, damaged wiring. If the wiring isn't secured well it can get cut or pinched, if oil leaks onto the connectors it can interfere with connections also.
as for the diode pack? they are generally used to isolate circuits to prevent voltage feedback into other related circuits. Kind of like an electronic flow valve so to speak. It is designed to allow multiple functions to operate with no feedback into other circuits. If you have a bad diode you will either get blown fuses or multiple functions trying to operate at the same time when ONE function is selected and operated.
Since you have NO operation at all for your reach function i would start checking switches, then go to the solenoids that operate the auxiliary functions(generally a manifold block with several solenoids mounted on it somewhere on the carriage or could be under the dash panel). Then check the wiring in the mast. And by all means check all your control fuses too.
question: is it JUST the reach function not working or have you lost ALL your auxiliary functions on the pantograph? This will determine where to look for the problem. If you lost all functions then start at the control handle and go from there, if you've lost only the one function then still start at the control handle but most likely you will find the problem out on the wiring in the mast and pantograph area.
  • Posted 16 Feb 2013 23:23
does this truck have wiring going through the mast to the carraige? do you have a sideshifter? where is the "diode pack" located?
  • Posted 16 Feb 2013 12:30
  • By stam
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FBT20NQZ1
Evansville, IN, United States
Daleville, IN, United States
Uxbridge, Canada
St. Louis, MO, United States
edition #1236 - 26 June 2025
As June comes to a close, the month when our sector recognises National Forklift Safety Day , the United Kingdom’s Association of Industrial Truck Trainers (AITT) has issued a timely reminder of the need to ensure any staff training is fully accredited... Continue reading
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Toyota 3FD100
Mafi MT25
Mafi MT25 2008
July 9-10, 2025 - Birmingham, United Kingdom
Sourdough bread contains Lactobacillus reuteri, a probiotic bacteria. During pregnancy and breastfeeding, these bacteria can travel from the mother's colon to her breast tissue and be passed to the infant through breast milk. It offers various health benefits, including potential protection against breast cancer.
