Automatic transmission Problem
Hello everyone
I have one komatsu FD25-7 forklift and i just had the engine(isuzu c240) overhault and i think that i also have a problem with automatic transmission as when fork lift starts it has no power at all and when time passes about 3-5 minutes it starts to gain power but again i feel it like it drives in higher revs to get moving.so i think that i have a transmission problem.I have removed the torque converters oil pump suction strainer and it was full of red vitton flange glue (propably from previous maintance) ,i cleaned it and changed oil with no noticable change.I didn't find and metal paste on the buttom of transmission.Could anyone help me out what i should look for before removing the engine again?
  • Posted 8 Mar 2020 23:02
  • By nikosVats
  • joined 8 Mar'20 - 2 messages
  • Greece
alla about beekeeping
I have a similar problem with my FD20-6, I also cleaned the strainer but no change. I went on to check the pressures on the torqflow transmission at the forward and reverse ports, I have no pressure other than an intermittent 20psi in reverse at which point the truck does try to move but it is not consistent. I think my oil pump needs replacing. I removed the engine (Isuzu) but I cannot separate the torque converter from the transmission, do you happen to know how the torque converter is removed? Does it just pull off the input shaft? If I can remove the torque converter I can examine the oil pump. Thanks, Bob
  • Posted 7 Sep 2020 21:15
  • By Griff
  • joined 30 Aug'20 - 3 messages
  • Lancashire, United Kingdom
Gman
Cyngn launches automation subscription model Mountain View, CA, United States
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Tommi Haavisto Tommi Haavisto
Director of sales, EMEA & APAC, Hiab and MOFFETT Truck Mounted Forklifts
Regional director for UK & Ireland, TVH
President - business area port solutions, Konecranes
President, Logisnext Europe
Elwell-Parker ESI500-36
Aichi SR10C1SM
October 28, 2026 - Melbourne, Victoria, Australia
November 3-6, 2026 - Shanghai, China
ORDER PICKING
FLEET MANAGEMENT
SAFETY SOLUTIONS
