Atlet UNS Fault code E71
Hi
We have an Atlet UNS Tergo 140BTFVXE675 serial number 20707/04 2002, when you go to lift hydraulics motor spins slowly mast creeps up and comes up with E71, the customer also reported seeing something on the dash about hydraulic motor overheating.
Guessing the sensor bearing in the hydraulic motor is playing up anyone able to confirm this please
Regards
Paul
  • Posted 2 Dec 2015 21:13
  • Discussion started by P_E_G
  • Kent, United Kingdom
Hi friends
Atlet UNS161
Showing error continues E65
Pls help me as soon as possible
  • Posted 29 Mar 2019 15:58
  • Reply by azhagesan_n
  • Dubai, United Arab Emirates
check the cooling fan between the drive & pump motors also check the battery voltage, should not go under 42 volts if it do's e71 error code show in the display the means height low voltage, charge the battery when you work the truck to hard yes it' overheat's let it cool off and then drive it if eveything it ok, if it was the bearing sensor it will not drive at all or lifts and cutt of, calibrate hydraulic levers
regards
  • Posted 2 Feb 2016 14:40
  • Reply by GUANAJUATO
  • Illinois, United States
Just to give some closure to this, changed the sensor bearing on the hydraulic motor cured the problem
Thanks again tassos_t
  • Posted 18 Dec 2015 04:02
  • Reply by P_E_G
Hi P_E_G
check your mail.
  • Posted 3 Dec 2015 01:45
  • Reply by tasos_t
  • ATTICA, Greece
ROYPOW
St. Louis, MO, United States
Newnan, United States
June 3-4, 2025 - Sacramento, CA, United States
The oldest known unopened bottle of wine was recovered from a tomb in modern-day Germany. The bottle is around 1.5 litres and believed to have been produced between 325 and 350 AD. There are currently no plans to open the bottle.
Toyota 8FG25
Unicarriers FHGE35T5S
