Hi,
I have a Atlet CSH160 in my workshop for some work, one of the problems is has is that when there is a any load on the stacker, the drive motor dosn't generate sufficient torque to drive the machine. It is an AC motor.
No error codes are showing and I spoke to the dealer who says the control needs to be calibrated. However, they are somewhat reluctant to give me the procedure for calibrating the control board.
Does this diagnosis sound right and can anyone tell me how to calibrate it?
Thanks
you must have A calibrator You must check the settings
There is activate A switch thats what see the Box
I got the calibration for the truck you need realy a calibrator.
I now that A calibrator cost About 250 dollars
Or I must come to the emmirates A option
Or send A calibrator
JOHN.
Hi,
It is an AC-0 Inverter and we hav just fitted a new one. The machine is now working but only in creep mode and the small turtle is showing on the display. I have cannot get it out of this mode and don;t have access to a calibrator.
Could you offer any advice?
Thanks
Hello
Do you have A calibrator
What type motor is mounted A sauer-danfoss motor Or kordell motor
Is the battery full
What's standing in the menu
Hardware settings, options , Adjustments or main menu give me the settings compleet
When you give me the data I check It en I give you the data whats need for the Atlet
What is standing On BOX AC 0 Or AC 1
Kindly regards
John.
Netherlands
