All Hydraulics not responding
BOught a used lift. Used it for a while and had not one issue with the machine at all. I got sick. Had to park it no one moved it or touched it for 2-3 months. Battery appears to be in good health and machine moves but hydraulics do nothing at all. Hydraulic motor appears to always be running. Not sure where to look for problems from here. Really could use some help or a service manual.
  • Posted 25 Dec 2014 03:16
  • By jackie_h
  • joined 25 Dec'14 - 7 messages
Wise men don't listen to other wise men they use their common sense and abilities to help others.
The switch to the side of the control handle was the issue. Thanks for your response. It was covered in grease found when tracing back lines. Thanks for the replies. So after getting that problem solved hit another problem.
  • Posted 19 Jan 2015 01:42
  • By jackie_h
My e-mail is in my profile. I found a box not checked to notify me when someone responding. I fixed that I hope. I did not think anyone as responding, Sorry guys.
  • Posted 19 Jan 2015 01:38
  • Modified 19 Jan 2015 01:55 by poster
  • By jackie_h
B108V10429E is SN of machine on nameplate
  • Posted 19 Jan 2015 01:36
  • Modified 19 Jan 2015 01:37 by poster
  • By jackie_h
Checked name plate. E50B is all it states. It appears to be a printed label from Hyster-original manufactuer. Very legible and easy to see. Unknown if I should look else where.
Found it to be a sticking contactor that was Normally open from grease build up and it recently got very cold here found it would work when warmed up etc..
  • Posted 19 Jan 2015 01:34
  • By jackie_h
would this happen to be an E50BS model?
has an EV-1 system in it?
check the pump contactor tips and make sure they are not welded shut also. Like kevin says it might be a control handle switch stuck but i'd check the contacts on the pump contactor too.
  • Posted 25 Dec 2014 18:06
Have an email to post in your profile???
For the hydraulic pump running all the time.....on the side of the control handle assembly should be a switch this needs adjusted,might be a cover that has to come off first to get to it.....how is the hydraulic fluid...full and clean? Filter??
  • Posted 25 Dec 2014 04:17
  • By kevin_t
Serial number of truck?.......are you positive the battery is fully charged????
  • Posted 25 Dec 2014 03:34
  • By kevin_t
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
TCM FD115-3
Terberg RT403
