Al 13 code
Hello
I have a yale MPB040-EN24T pallet truck
First it started showing AL 21 code and starts blinking red light and unit stops from working
I took it to mechanic for almost six times now but they are not able to fix it Now it shows error code AL 13 and red light starts blinking and unit stops
Everytime it does this, first it slows down.
The problem is sometimes it then starts working perfectly fine, then the same problem begins.
Can someone help me with this
  • Posted 27 Sep 2022 12:35
  • By Inderjeet_Singh
  • joined 27 Sep'22 - 3 messages
  • British Columbia, Canada
Thanks
  • Posted 2 Oct 2022 07:15
Al 13code is used if the control is loaded with 1.O8 software it is talking about that the motor field has a problem check the connection to the motor fields to make sure they are not loose also the stud inside the motor could have a problem l would pull the motor and have it checked if it checks good re place controller but l seen same problem and it was the fields studs inside the motor hope this helps
  • Posted 2 Oct 2022 07:06
  • By Scott_
  • joined 16 May'21 - 344 messages
Scott
Just to be safe, since batteries are new, remove all cables and check each battery for voltage. You state that sometimes it will operate correctly, seems to be a failing connection. Verify all battery connectors are crimped tight and make a good connection. With new batteries you can have a connection problem if not cleaned first. Where the estop switch is at, check all wires and connections are tight. Have seen issues with failed crimps on male slide on connectors. Good Luck
  • Posted 1 Oct 2022 01:07
  • By garland_m
  • joined 16 Oct'09 - 225 messages
  • Virginia, United States
Work Hard and Fish Long
All batteries are changed to new
  • Posted 30 Sep 2022 01:13
I don't show an AL13 code for this machine, but if it slows down before malfunctioning maybe the battery is involved. Check the battery voltage under normal operations and when the jack starts to slow down.
  • Posted 30 Sep 2022 01:12
  • By lumberjack
  • joined 27 Jul'07 - 192 messages
  • Maryland, United States
Hangzhou Maxlion Forklift Imp & Exp Co., Ltd.
Neptune was discovered in 1846. It then took 165 years, or until 2011, for the planet to complete one orbit of the sun.
Hitachi HX64B2
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
