Access 7
RM 6000 with No power to Access 7.
(both 5 wire conductor cables were ripped out.)
Replaced both with crown made cables but Access 7 has no power. Swapped out Access 7 to rule it out and no change.
Code 823 for reach calibration is only code I get. Assuming no battery negative making connection
  • Posted 10 Mar 2022 23:14
  • By Murphy6011
  • joined 10 Mar'22 - 7 messages
  • Mississippi, United States
Murphy6011
Big problem where I work.
5 wire was great place to start.
Likely will need to replace harness for
Access 7
Typically wire damage here as well.
It's a shorter harness.
Also, make sure 5 wire cables are plugged in good to the 5 wire connectors at the bottom of the cylinder. Have found them almost plugged in an it was enough to cut power
  • Posted 3 Aug 2022 11:13
  • By Murphy6011
Murphy6011
Linde C4230TL5
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
F. Uchiyama
