Accelerator Linde H25D-03 351
I have a problem on Linde H25D-03 351, when we start the machine the hidraulic engine accelerator goes to max rotation. It hapened after repair oil leaks on control valve block. Any idea will be very welcome.
Thank you
  • Posted 9 Apr 2012 23:58
  • By goncalosousa
  • joined 12 Sep'05 - 42 messages
  • Leiria, Portugal
Hi goncalosousa;
The hydraulic engine's accelerator controller is operating on a pressure differential between the rod end and barrel end of the cylinder. This pressure difference is controlled by the item you repaired that leaked.
With the engine and hydrostatic drive at operating temperatures and your truck's pedal adjustment unchanged from before the leak was repaired, and engine running, brake pedal applied, depress the FWR and REV pedals fully. Then with the pedals released, pull back on the lift lever. Hold lever in position for a moment and then release.
The speed control servo cylinder moves the injection pump's lever to the stop each time, and the engine attains the upper speed of 2250 (+50) and then drops tp a low idle of 750 rpm. If this is not occurring a check of the entire hydraulic engine speed control will need to be performed to isolate and clear the cause.
  • Posted 12 Apr 2012 11:27
  • By MEngr
  • Missouri, United States
hi , do you have change the pressure setting of the accelerator? It have a svrew on th evalv block for setting hard or slow. It works with low pressure
  • Posted 12 Apr 2012 05:10
  • By gc_d
  • Zuid-Holland, Netherlands
Regards gc_d
Bolzoni SpA (Group HQ)
