AC vs DC application
What is the advantages w/ AC drive/lift systems w/ respect to conventional DC? Are they (motors) repairable as easily as DC motors are? Do they hold better on lifespan? How about real world, low battery operations? problems w/ convertor controllers? motor problems? Is this smoke and mirrors or a viable system? Any ,"real world application," input would be appreciated.
YANNI
  • Posted 19 Jan 2012 22:18
  • By 7777
Just seen a video on you tube where a company is offering a 30 ft boat using 2 48v batteries and is AC driving it. I am wondering what the range on that puppy is going to be.
  • Posted 10 Feb 2014 08:44
  • By RCAV8TOR
  • Alabama, United States
Hi Forkingabout,
I am in need of a 72 volt series wound DC motor. Cheap as possible as I am on a budget. It would have to be 12KW and 12hP if possibe.
Any help would be appreciated? Sorry if this is in the wrong thread.
Regards
  • Posted 10 Feb 2014 05:51
  • By Ernie
  • joined 30 Mar'13 - 3 messages
  • Manchester, United Kingdom
willsmith@ntlworld.com
If you are in the business of running a warehouse or own a rental fleet and are directly comparing new AC vs DC, then AC would be the choice. As others have said, less parts, less maintenance, etc.
With a fleet of trucks my experience is the TCO will be lower on AC. With 1-2-3 pieces the cost savings will be minimal, especially if an AC controller needs replaced.
Choice of equipment manufacturer will have a big impact on whether there is any benefit to an AC powered forklift. I have many Crown Reach Trucks/ SP's I service and the costs are all low. My rental fleet is mostly Raymond Reaches/ OPC's, the costs with the AC is much lower. The new AC units are much better than a DC Easi that was expensive to run.
Do not do much work in high cycle environments like grocery so I have not seen the benefit of faster speeds. My current belief is that the productivity is close enough to be considered equal.
If you are moving from an older Raymond Easi to a new AC
  • Posted 27 May 2012 23:36
  • By ForkLiftACE
  • joined 8 May'12 - 8 messages
ForkliftACE - Your helpline to forklift diagnostics
Twitter - @ForkLiftAce
No, thats one of the advantages of AC.
In the last 6 years I've replaced just 1 AC convertor due to a fault & another AC convertor due to the apprentice blowing it up changing the traction fuse ( he shorted the unit out by dropping his spanner across all the terminals )
I've not had to replace a single AC motor, only things ive done is bearing replacement including the odd speed sensor bearing.
  • Posted 25 May 2012 18:42
  • By Forkingabout
  • england, United Kingdom
Are there no brushes in an ac motor?
  • Posted 25 May 2012 18:07
  • By 7777
I personally prefer the dc systems. DC = brushes, contactors,contactor tips, component testing and replacing, hence more work to sell during a pm. AC controllers are much more complicated internally but as a forklift tech most of us will just replace inverters, encoders, and switches after a few simple test and/or an error code.
  • Posted 25 May 2012 10:17
  • By jeremy_s
  • joined 28 Mar'08 - 205 messages
Half of the 30 Raymond orderpickers running around my warehouse are early 06s with AC drive. I haven't lost a motor yet (I'm knocking on my wooden desk as I type this) so worrying about having to rebuild one is a mute pointi think.
  • Posted 25 May 2012 05:45
  • By joe_d
  • joined 25 May'10 - 253 messages
Ain't nothing I can't fix but a broken heart and the break of day!
I was under the impression, ac motors are not cost effective to rebuild. I'm thinking this ac stuff is all smoke and mirrors
  • Posted 25 May 2012 04:47
  • By 7777
The Only downside can be I suppose the cost of AC motor controllers when they fail compared to most DC controllers.
The controllers themselves are harder to repair and more expensive to replace than many traditional DC controllers.
  • Posted 25 May 2012 02:20
  • By elektrodrive
  • joined 2 May'08 - 744 messages
enquiries@elektrodrive.co.uk
Ac systems are much easier to troubleshoot than the older dc systems. Inverters when bad most times are easy to detect. Much less operating parts. External sensors will be a welcome change however.
  • Posted 23 May 2012 22:25
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
Only things ive ever had to replace on AC motors over the years are the bearings & the odd speed sensor bearing.
Newer stuff with AC wont have a speed sensor bearing, it will have a toothed wheel inside the motor & an external sensor - like an ABS setup on a car.
  • Posted 23 May 2012 19:03
  • By Forkingabout
The advantages of AC power on the DC motor are: low maintenance AC motor by not using brushes, lower power consumption lets you use batteries with less capacity to amps hours. Are easier to repair when using copper wire in the coils which is cheaper than copper hearth using DC motors.
  • Posted 23 May 2012 13:49
  • By hector_v
  • joined 17 Nov'11 - 42 messages
  • Puebla, Mexico
Toyota launches three new stackers Columbus, IN, United States
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
VETTER Industrie GmbH
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
Highland, IL, United States
Orlando area, United States
