8FGUC25 toyota code 61-2
it appears to be a sas/ops code what could be the problem also how do you clear the codes
  • Posted 8 Dec 2009 23:41
  • Discussion started by johnny_g
as your looking at the diagnostic port plug located below the fuse box facing toward you with the hood open, the top center and the middle second from left terminal need to be shorted together (jumper wire), turn lift ignition on, the engine light will blink, press the gas pedal to the floor 5 times and shut the lift off, remove wire and start lift, code will return if the error is valid.
  • Posted 9 Dec 2009 05:21
  • Reply by tristan_m
  • Louisiana, United States
edition #1229 - 8 May 2025
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
