8fgcu25 not idling well .
Hello I am working on a toyota 8fgcu25 that is hunting for an Idle any ideas? No codes!
Thanks
  • Posted 25 Oct 2011 07:48
  • By tundra
  • joined 29 Sep'11 - 5 messages
  • Alberta, Canada
sounds like regulator/vaporizer is freezing up. low on coolant or air bound.
  • Posted 25 Aug 2018 09:58
  • By Bart
  • joined 16 Aug'16 - 7 messages
i have at 8fgcu25 its hard to start and will idle fine till the temp is at the half way point to then will start running like *** ive done and tryed everything that i have seen on here and no luck
  • Posted 16 Jul 2018 21:21
  • By mark14
  • joined 16 Jul'18 - 1 message
  • United States
mark behrens
Also try the taking the electric valve off the side of the carb horn and clean it out thoroughly. I have seen them build up oil sludge on the needle valve and the horn.
  • Posted 8 Mar 2012 13:06
  • By rogeriwt
I have similar problem at 3000 hrs -hard to start and stalls after a long high rev drive -found the vac hose off of the intake hose between air filter and intake -still doesnt want to idle or start without keeping your foot on accelerator. I'll try to adjust mixer and clean throttlebody and clean or replace the inline fuel filter.
  • Posted 6 Mar 2012 21:56
  • By troy_m
Thanks, We had the results as you. We are now up and running
  • Posted 9 Nov 2011 02:11
  • By tundra
  • Alberta, Canada
We have resolved this idle issue on the units that were being affected by adjusting the idle mixture at the regulator. This can be accomplished by knocking out the cap that covers the idle mixture screw on the top of the regulator and turning the idle screw until the unit stops surging. The idle speed may have to be adjusted once the fuel mixture is adjusted. No parts required. This issue may be attributed to the units being set at near sea level and then being put into service at a higher elevation.
  • Posted 3 Nov 2011 14:26
  • By Jenn
  • joined 27 Oct'08 - 8 messages
  • Alberta, Canada
Yes it is inline by the regulator.
  • Posted 3 Nov 2011 08:31
  • By rogeriwt
Well we have ordered a new throttle body assebly and just waiting for it to come in. Where is the Lp filter on these ones. Is it just an inline one at the regulator?
  • Posted 28 Oct 2011 00:41
  • By tundra
  • Alberta, Canada
I am assuming that you have replaced the lp filter. You will probably have to hook up a Toyota hand held to see what the injection period is, it is possible that the lp regulator is messing up just enough to idle poorly and not throw a code.
  • Posted 27 Oct 2011 12:06
  • By rogeriwt
I have 4 units doing the same thing did you find out what this is?
  • Posted 26 Oct 2011 09:52
  • By Jenn
  • Alberta, Canada
Thanks, Yes i have tried that but it didnt help. No vacuum leaks, ignition system looks good. If i create a vac leak the computer will compensate and it sounds good for a few seconds and then it goes back to running like crap. No codes.
Clayton
  • Posted 26 Oct 2011 00:19
  • By tundra
  • Alberta, Canada
probably a build up in the throttle throat... remove and clean it with carb spray... it's a common issue.
  • Posted 25 Oct 2011 08:48
  • By rick_c
  • joined 30 Jul'09 - 204 messages
technology: (no user serviceable parts inside)
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
