7FBE18 DRIVE FAULT
LEFT SIDE DRIVE MOTOR LOCKING UP IN FWD & REV. I HAVE REMOVED MOTOR AND HAD CHECKED OUT AND IS OK. ANY THOUGHTS ? THIS IS A A/C DRIVE MOTOR SYSTEM.
THANKS
  • Posted 25 Mar 2010 11:09
  • Discussion started by mrforklift
  • Queensland, Australia
Check with your Toyota dealer there have been a problem since 2003-aug2006.
  • Posted 25 Mar 2010 23:11
  • Reply by LOGIC
The simple things in Life are the greatest rewards!
Your looking in the wrong spot. Toyota had some issues with the final drive gear box bearing failing. Switch from gear oil to a transmission oil. Fluid should be replaced every P.M. Both sides. Take the wheel off, remove the bolts an the whole gear assy will come apart.
  • Posted 25 Mar 2010 22:42
  • Reply by Prentice
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
edition #1229 - 8 May 2025
Aichi RX07B
Toyota 4FD240
