Cat Lift Trucks (& Caterpillar) GC15K:
50% power
LP gas, 4 cyl, late model cat lift, one ton. Ran fine, changed oil, oil filter, air filter. About 3 days later the unit just loses power if the pedal is pushed beyond 50%. I know the oil change had nothing to do with it, but that's all I did. Idle is fine, starting is fine-seems like it's starving for fuel-changed tank- no difference.
Thanks for any help
  • Posted 9 Jun 2009 00:14
  • Discussion started by catlift
  • Connecticut, United States
it's all your fault any way, you touched it, you own it, and are married to it, now...
you don't say which serial number series??
maybe the hose that runs between the mixer and the regulator?
maybe an extra 'o' ring in the truck half of the quick disconnect for the LPG tank?? (any is too many)
Maybe you need to also do a tune up?
  • Posted 9 Jun 2009 08:05
  • Modified 9 Jun 2009 08:05 by poster
  • Reply by edward_t
edition #1228 - 1 May 2025
