343 fault
having same issue someone had 3 years ago. On descent lift would alarm out about 4 feet from ground, 343, joystick, alarms. Put in new joystick and power module, still getting same faults. This happens during operation from joystick, ground control and manually pressing down valve solenoid
  • Posted 4 Feb 2021 02:35
  • By Thongsoy
  • joined 3 Feb'21 - 1 message
  • Minnesota, United States
thongsoy
I had this same problem a year ago. Batteries were good and static strap was good. Once it coded out I marked on either side of cable pulley so I knew where the area was that went over the pulley when it failed. Then I pulled the cable off the pulley and I could bend the control cable back and forth until it coded out. I changed the cable and the problem went away.
  • Posted 29 Jul 2021 13:20
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
as bluenose suggested do check the mast cable...
but...after looking in the service book the only mention of any sort of 3xx code is 300-399 and refers to traction control module-fault condition on page 6-38.
when you look at the troubleshooting for that it has several things to check.
1-recycle the key 5 times allowing a 10 second interval between cycles (proceedure to clear codes).
2-check the ground control station display and see if there is a code displaying there (if you havn't). It only suggest 2 codes there and it's either replace traction control module or go to next step 5.
3-confirm batteries voltage etc.
4-check battery voltage while charging.
5-check for short in harness between ground control station P5 to traction control module.
So maybe there are other things besides the mast cable that will cause this.
it's suggestions rule out the mast cable. (but check it anyway).
  • Posted 12 Mar 2021 22:09
try removing the overmast cable from pullies and raise, lower mast. I f no code,
might be cable mate.
make sure static strap is on and chect for sorts to frame
good luck mate!
  • Posted 12 Mar 2021 13:28
  • By Bluenose
  • joined 2 Apr'14 - 31 messages
  • Nova Scotia, Canada
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
Taylor T520M
Rail King RK330
Lithium Storage
Leading China-based developer and manufacturer of Industrial Lithium Batteries.
