33057 code
Looking 4 a explanation of this code.Thanks Barracudabear,
  • Posted 20 Apr 2024 07:10
  • By Barracudabear
  • joined 4 Feb'16 - 12 messages
Will do thanks!
  • Posted 22 Apr 2024 23:18
  • By Barracudabear
Cuda,
This code is for communication error between the dash display and the VSM. You will need to verify the CAN wires, yellow and green twisted pair, from the VSM to the display. The steer column has a communication port for programming. Check between pin A and B, using ohms should read about 60. 120 and your missing a termination resistor. 0 ohms, the yellow and green are shorted together. Voltage reading should be about 2.5 volts per wire. You will need to verify the wires from the VSM to the display. Make sure all connections are tight. Good Luck.
  • Posted 22 Apr 2024 23:13
  • By Fishmech
  • Virginia, United States
Terberg RT223
Taylor TT300
Lift Tek Elecar
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
Lift Tek Elecar
edition #1280 - 7 May 2026
In this week’s Forkliftaction News , it’s financial reporting season with Hyster-Yale, KION Group and Konecranes all reporting revenue falls for Q1, yet maintaining their forecasts for moderate growth and stable sales volumes for the year... Continue reading
