3.5 t LPG Nissan UGL02A35DU
Hi Guys Have a 3.5 t LPG Nissan UGL02A35DU YOM 2007 starts OK but will only rev just above idle then cuts back, showing E38 on dash display think it is a K51 engine not sure any help would be greatly appreciated. Nick
  • Posted 14 Aug 2012 00:39
  • By nick_c
  • joined 17 Jun'11 - 116 messages
  • south glos, United Kingdom
Hi Kevin,
I've no experience with Nisan truck but I do know that the Cat trucks have the same engine and I suspect the same engine management system, any way Problem list for E38 is the LPG injector fault when a short circuit of the fuel pressure sensor occurs
When an abnormal rise in fuel pressure in the fuel pipe from the LPG vapo continues for an excessive length of time.
If the wiring is anything like the Cat trucks then the wires may break around and near the injector and sensor but you won't see the break because it happens inside the insulation near the connectors waggling them may produce a reaction like you can rev the engine ,
The other bad news is that even if you cure the fault you will probably need a lap top to clear the code, or you may be able to do the pedal dance to clear the code , have a look through old cat posts it has been listed on several occasions.
Regards Titus
  • Posted 14 Aug 2012 02:36
  • By Titus
  • joined 6 Jul'10 - 185 messages
Code E38 is for LPG fuel pressure to high,it either needs adjusted or the regulator needs rebuilt.
  • Posted 14 Aug 2012 02:14
  • By kevin_t
Muncie, IN, United States
VETTER Forks, Inc.
Deborah Baker Deborah Baker
Toyota 4FD240
Ice 28INCH-AUTO-SCRUBBER
USD8,350
