2FG10 1971 CLUTCH REPLACEMENT
Hello to the forum
My clutch failed and i am trying to find a way to remove the cover assembly and the clutch disc.
I have been told that there is a safety pin to remove do gearbox shaft can withdraw and leave room to remove the cover assembly and disc.
However I can't find any pin. Any help would be highly appreciated.
https://youtube.com/shorts/dVzqClzi4_c?feature=share
  • Posted 4 Jul 2022 22:44
  • Modified 4 Jul 2022 22:48 by poster
  • By Rainfallgr
  • joined 1 Jul'11 - 12 messages
  • kilkis, Greece
Very glad I found this thread. Thank you for the part numbers. We have a 2FG10 that has needed a clutch for years and we finally have some downtime to fix it. Do you have any lifting information for the 2FG10? I don't have a certification plate anywhere on mine so I'm not even sure what it's lifting restrictions are.
  • Posted 3 Apr 2024 11:24
  • By Corey_Marks
  • joined 3 Apr'24 - 1 message
  • British Columbia, Canada
Clutch disc: 31260-20130-71, Aisin DW-001V
Clutch cover: 31210-10111-7 Aisin CW-009
Bearing : 9036345079 Aisin BT-027
Clutch dimensions outside 225mm inside 160mm 21 teeth
Bearing dimensions: outs. Diameter 73.8mm , inside Diameter 45mm thickness 16mm
  • Posted 15 Jul 2022 05:51
  • By Rainfallgr
  • kilkis, Greece
It doesn't have thread when parts arrive i will post back parts numbers and dimensions. It might help someone in the future
  • Posted 6 Jul 2022 16:28
  • By Rainfallgr
  • kilkis, Greece
The first hole you see in your video, (there are 3 holes) it should have threat inside it.
If you can assemble without pressure, thats fine, but mostly diffelcult to put it all thogether
  • Posted 6 Jul 2022 16:24
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
johnengels2@hotmail....
To be honest i just removed the clutch cover.
I have seen other video where people are installing 3 bolts to the clutch cover for installation of the clutch and then removing them.
My clutch cover do not have any threaded Holes. So how can I put pressure on the clutch prior to the installation?
Here's a video of clutch cover
https://youtube.com/shorts/mxT9y7buk2s?feature=share
  • Posted 6 Jul 2022 16:06
  • By Rainfallgr
  • kilkis, Greece
Just put pressure on the new clutch and mount the 3 bolts, then re assemble, don,t forget to take out bolts.
  • Posted 5 Jul 2022 23:11
  • By John50
  • Netherlands
100% success
https://youtube.com/shorts/yYWH7rCkLEA?feature=share
Is there anything that I should be careful when assembling back the clutch?
  • Posted 5 Jul 2022 23:04
  • By Rainfallgr
  • kilkis, Greece
Thank you John for your reply, i will check tomorrow morning and post back?!
  • Posted 5 Jul 2022 06:15
  • By Rainfallgr
  • kilkis, Greece
First put pressure on the clutch and place 3 bolds in it.
Put forks up and look from the front side of truck to the gearbox, in line with the gearbox there is a bold, take that one out and you see the pin.
You can pull it back to releave the clutch, there should be room to take it out.
  • Posted 5 Jul 2022 05:04
  • By John50
  • Netherlands
  • Posted 4 Jul 2022 22:48
  • Modified 4 Jul 2022 22:49 by poster
  • By Rainfallgr
  • kilkis, Greece
Impact Handling rebrands to Aprolis Handling Long Eaton, Nottinghamshire, United Kingdom
Bolzoni SpA (Group HQ)
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
October 12-15, 2026 - Detroit, MI, United States
October 22, 2026 - Sydney, Australia
January 26-27, 2027 - Balikpapan, Indonesia
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
Kelly Stewart Kelly Stewart
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
at-large director, AED
COO, Intelligrated, Trew and Transnorm
