275 error code
i put the power lead in the wrong way round, now coming up with 275 valves controller fault, can anyone help me?????
  • Posted 22 Mar 2014 01:15
  • By aidan
  • joined 22 Mar'14 - 2 messages
  • essex, United Kingdom
Internal failure of the valve driver module.
No operation of the electro-hydraulic functions.
Probable Causes and Test Procedures
- Ensure all fuses are properly seated and tight in the fuse holders.
- Ensure all wiring connections are tight and secure at the fuse panel, key switch, and the battery disconnect switch.
- Check that the battery disconnect switch, the key switch, and the main contactor contacts are in the correct position and properly making contact.
- Recycle the key switch from the OFF to the ON position.
- Check all pins at the valve controller connector are tight and secure.
- Replace the valve driver module.
  • Posted 24 Mar 2014 19:58
model- J1.60xmt (545)
serial- J160ao2824c
thanks
  • Posted 24 Mar 2014 18:44
  • By aidan
need more info
full model number?
serial number?
  • Posted 22 Mar 2014 13:33
Terberg YT222
Yale GDP100M
Flesherton, Ontario, Canada
July 9-10, 2025 - Birmingham, United Kingdom
Daleville, IN, United States
Evansville, IN, United States
St. Louis, MO, United States
Uxbridge, Canada
Jeannette Walker Jeannette Walker
CEO, MHEDA
President, European Rental Association (ERA)
Chief marketing officer, JLT Mobile Computers
Crown Equipment celebrates 80 years New Bremen, OH, United States
US confidence index rises sharply Washington, DC, United States
