2007 hyster H90FT P005V01538F
OIL IN WATER WANT TO CHECK COMPRESSION ANY ONE KNOW WHAT COMPRESSION SHOULD BE?
  • Posted 1 Aug 2019 02:52
  • Discussion started by seanba
  • Washington, United States
thanks for the help !!!!!
thanks for info! really appreciate it! have a great weekend!
  • Posted 3 Aug 2019 10:22
  • Reply by seanba
if its cummins remember the little oil cooler on the back of the oil filter. could be cracked. test that before you go ripping the rest to bits mate
  • Posted 2 Aug 2019 02:35
  • Reply by stackerhacker
  • glasgow, United Kingdom
cummins engine:
Engine Compression
2944 kpa
427 psi
It is recommended that the compression pressure be checked and compared on all cylinders. All cylinder must be within 276 kPa [40 psi] of each other.
GM 4.3 engine:
"Install a compression gauge. Hold throttle open and crank engine with starter. The minimum pressure is 690 kPa (100 psi). The lowest pressure in a cylinder must not be less than 70% of highest pressure."
This is straight out of the hyster service engine section and it does not give a definitive pressure reading on the GM other than in that statement above, at "least" 100psi and there should not be more than a 70% difference between them.
  • Posted 1 Aug 2019 15:17
  • Modified 1 Aug 2019 15:18 by poster
  • Reply by swoop223
190 plus or minus 25.
  • Posted 1 Aug 2019 03:46
  • Modified 1 Aug 2019 03:46 by poster
  • Reply by BREWSKI
Hangcha CBD15
China
USD1,600
Ncn 110TH
Ncn 110TH 2023
Harrisburg, SD, United States
Wentzville, MO, United States
Ottumwa, IA, United States
Yale Lift Truck Technologies
