- Home
- Forums
Technical Troubleshooting
Raymond
550-OPC30TT
Raymond 550-OPC30TT:
2 Dead Machines
I now have 2 Machines with the same problem. They are exact sisters. The machines will run just fine and then if you turn them off they shut off and will not turn back on. So here is what happens when you key the units on and they don't start.
- Key on unit the below happens until you hear a click
- Operator Display does not light up
- Vehicle Manager Red light turns on solid and turns off with Click (Note: when unit is working this red light will blink)
- Lift Power Amplifier No lights until Click, flash red then yellow light begins blinking
- With the click the strobe light turns on
- Traction Power Amplifier No lights until Click, flash red then yellow light begins blinking
- Carriage Control Card Green light comes on and stays on, Deadman activates light
- No response from any controls
If anyone has any thoughts we could really use some help. Thank you
